Neue Einheiten
Regelboard und für die Übersetzungen
Gott :) (Admin)
Gott :) (Admin)
Neue Einheiten
Beitrag von Coki »
Im EXE Forum werden im Moment die Daten für neue Einheiten veröffentlicht.
Hier die bisher erstellten:
-> Charnel Golem (Devout): http://www.chronopiaworld.com/einheit.php?id=39
-> The Tainted (Devout): http://www.chronopia-deutschland.de/for ... 8294#p8294
-> Dusk Realm Hounds (Devout): http://www.chronopia-deutschland.de/for ... 8295#p8295
Gruss,
Meine Armeen: :ers: :schlange: :sch: :styg: :dunklenhauer: :sdk: :lak: :sum:
Bemalte Modelle 2024: 3 /3 / 9, 2023: 214 / 150 ('23: 214; '22: 31; '21: 260; ''20: 315)
Gott :) (Admin)
Gott :) (Admin)
The Tainted
Beitrag von Coki »
Quelle: http://forum54.oli.us/index.php/topic,5821.0.html
Datum: « on: June 06, 2009, 08:54:49 AM »
THE TAINTED (4-8)
CC RC PW LD AC WD ST MV AR DEF SZ CT
11 8 0 10 2 2 4 3 15 0 2 36
SPECIAL ABILITIES & RULES:
* Cause Fear
* Revolting Presence: Mortal, Draconic & Beast Models must make a LD test to charge a model with this ability. Failure means the action was wasted. Subsequent attempts may be made. Models with a LD of 13 or more are immune as are any models they directly command. No further checks are made by models in CC.
* Cannot Run.
* Extreme Putrification: When a Tainted is slain, place the model on its side. At the end of the turn in which it was slain when the activation counters are removed, place a boulder template where the fallen model was. It should be centered on its base. This represents the models extreme putrification and the toxic remains it left behind. Mortal, Draconic or Beast Models attempting to cross the tainted putresence must make an LD save or take a wound. If this kills them, replace the slain model at the beginning of the next activation with a new Tainted under the control of the Devout.
EQUIPMENT:
The Tainted attack with an Vile Blade (DAM= ST +5, Unlife Energies).
CLASSIFICATION:
Undead
PROXY:
To field these warbands, we recommend using the Blight models produced by Heresy. They may be found here: http://www.heresyminiatures.com/hv043.htm
TAINTED DISGORGER (1 optional per 4 Tainted, maximum 2 per warband)
10 11 0 10 2 2 4 3 15 0 2 44
* Cause Fear
* Revolting Presence: Models must make a LD test to charge a model with this ability. Failure means the action was wasted. Subsequent attempts may be made. Models with a LD of 13 or more are immune as are any models they directly command. No further checks are made by models in CC.
* Cannot Run.
EQUIPMENT:
The Tainted Disgorger attacks by disgorging a blast of Black Vomit.
(ROF- 1/2 (1x per activation), Range- 6", Small Explosion Template- DAM=11 (Place Template and roll RC attack. If you miss, the difference between what was needed and what was rolled is subtracted from the base damage to a minimum damage of 4)
If in CC, the Disgorger will not vomit but instead attack with a Savaging Maul (1x) Dam= 8. This is a natural attack.
CLASSIFICATION:
Undead
PROXY:
To field these warbands, we recommend using the Blight models produced by Heresy. They may be found here: http://www.heresyminiatures.com/images/ ... ster_1.jpg
Gott :) (Admin)
Gott :) (Admin)
Dusk Realm Hounds
Beitrag von Coki »
Quelle: http://forum54.oli.us/index.php/topic,5820.0.html
Datum: « on: June 06, 2009, 06:51:30 AM »
DUSK REALM HOUNDS (4)
10 8 0 10 2 1 5 5 16 0 2 28
* Steadfast, * Leap, * Ferocity LV-2. (+2 bonus instead of +1 as noted under the Ferocity SA)
* Hounds cannot be put on wait.
EQUIPMENT:
Hounds attack with a combination of claws and bites called a "Savaging Maul- (1x) DAM=11" It is a Natural Attack.
CLASSIFICATION:
Infernal, Beast
PROXY:
To field these warbands, we recommend using the HellHound models produced by Heresy. They may be found here: http://www.heresyminiatures.com/images/ ... etal_1.jpg
DeScha
Milizionär
Milizionär
Re: Neue Einheiten
Beitrag von DeScha »
Sind die Profile dann auch schon getestet wurden?
Gott :) (Admin)
Gott :) (Admin)
Re: Neue Einheiten
Beitrag von Coki »
Weiss ich nicht. Aber ich gehe mal davon aus.
Gruss,
Gast
Re: Neue Einheiten
Beitrag von Gast »
Naja, die Tainted sind ja nicht schlecht, aber auch recht überflüssig, find ich. Die Lakaien haben ja ausreichend vielfältige und brauchbare Infantrie.
Eine gute Fernkampfeinheit wär wohl sinnvoller :neutral: .
