Mutant Chronicles fuer Unreal Tournament
Dieses Forum ist für alles gedacht, was nicht unmittelbar mit dem Thema Chronopia und Warzone zu tun hat.
Kaal979
Milizionär
Milizionär
UTDoomTrooperIIIPreversion
Beitrag von Kaal979 »
:teufel: :sauer: :sauer: :sauer:
UTDoomTrooperIIIBeta2400 fertig!
http://forums.beyondunreal.com/showthre ... ost2237393
Fail! by Kaal979
As Leutnant Hausner awoke all he remembered was the ambush on the mishima transport had failed.
The vehicle got stopped and assaulted but there ejected a double of the expected
samurai crew and critical combat followed.
Obvious with much luck his skull mask changed a machine gun bullet and he became unconciuos.
Now all his comrades and many samurai lay diversed around the vehicle.
But there were more - he carefully lifted his head more and saw one squad of
estimated seven undead legionaires inquire the corpses.
Hausner silently feeled for his deathdrum machine gun and in a quick action fired at the enemies.
They surprisingly fell down except one bigger which ate the rest of the rounds.
After the last was terminated the missions objective returned to the Leutnant.
He stood up and entered the burning transporter to destroy the presumed strategic documents.
A file case contained the plans which showed some concepts and japanese script.
Suddenly he heard a demonic laughter from behind and quickly turned ready for defense.
But he saw nothing and in the same second his thrat opened and all turned red.
Kaal979
Milizionär
Milizionär
Maps
:arrow: :arrow:
Im Unreal Forum gibts neue Map Charts!
Kaal979
Milizionär
Milizionär
UTDoomTrooperIIIFinalbeta20
UTDoomTrooperIIIFinalBeta20 - Die letze Beta Version for dem Komplett Release!
:confused:
Unser BeyondUnreal Thread wurde ungluecklicherweise geloescht!
Aber ich hoffe bei UnrealAddicts haben Sie mehr Verstaendnis.
http://www.unrealaddicts.com/forums/ut- ... -99-a.html
"Auch ein blindes Huhn findet mal ein Korn!"
Kaal979
Milizionär
Milizionär
DOWNLOADS
UA stellt ploetzlich auch CopyRight Fehler fest und hat die Links geloescht.
Ich erkenne die Anschuldigungen natuerlich nicht an.
Aber UTDoomTrooperIII ist sowieso bald fertig und dann fuege ich die Links als Text Datei hinzu.
Kaal979
Milizionär
Milizionär
Ok- vergessen wir die Zänker in den Unreal Forums!
In dieser File ist alles drin was DoomTrooper Fans sich wuenschen können.
:cool: UTDoomTrooperIIIFinalBeta20:
http://www.megaupload.com/?d=FJITLHCO
Kaal979
Milizionär
Milizionär
Xan Scaling
:D Scale models up or down
Open UED\ActorClassBrowser open the packages skeletalchars313 and skeletalcharsfix313
and search all Xan under Pawns\Bot and PlayerPawn. Open all their property windows and
set Display\DrawScale to 1.2. Now goto view check ShowPackages
and check the skeletalchars in the appeared window.
Then save selected packages and Youre done - Xan is now good one head bigger.
(Works of course best with the health cheat already described in the UTDoomTrooperIII read file.)
EDIT: BTW - You can actually edit the health as well in properties\pawn!
ERDIT2: Also edit the collosion height to make even bigger ones!
Kaal979
Milizionär
Milizionär
UTDoomTrooperIIIFinalbeta22
:cool: UTDoomTrooperIIIFinalBeta22:
http://www.megaupload.com/?d=CB8UE0EB
Beachtet die neuen Gesichter der Bauhaus Rangers!
Hat ungefaehr 2 Wochen Vollzeit Arbeiten gekostet.
Als naechstes verbessere ich alle Gesichter angefangen bei der Darl Legion.
Aber nicht bevor ich mein anderes Projekt - die Weird Corps Skins fuer original UT fertig habe.
http://www.unrealaddicts.com/forums/map ... mbies.html
Kaal979
Milizionär
Milizionär
Unique AlienQueen und WeirdCorps Skins
Ich habe ein paar warzonische Skins exklusiv fuer UnrealTournament gemacht:
http://www.destinationunreal.com/module ... =1110#1110
Kaal979
Milizionär
Milizionär
Unreal X-Mas!
Die DOOMTROOPER Skins werden sich wohl noch länger hinziehen.
Wie es neuerdings aussieht werde ich via MonsterHunt GameType
SinglePlayer Levels mit Bot-Support machen.
Bis dahin empfehle ich meine UNREAL TOURNAMENT Kollektion
downzuloaden:
http://www.unrealplayground.com/forums/ ... hp?t=55040
oder:
http://www.oldunreal.com/cgi-bin/yabb2/ ... 1290946875
oder:
http://forums.ut-files.com/unique-alien ... -t156.html
:haha: :cool: :D
Map Preview Seiten:
http://www.mapraider.com
http://www.map-factory.org
Kaal979
Milizionär
Milizionär
MH-Brutes][Final2
Ich habe eine letzte kleine Verbesserung der UT MonsterHunt Map Brutes][ gemacht!
DOWNLOAD:
http://www.filefront.com/17753811/MH-BRUTES][Final2.rar
Alternative1:
http://www.fileplanet.com/218167/210000 ... es2Final2-
Alternative2:
http://www.megaupload.com/?d=WDQK0O8D
Kaal979
Milizionär
Milizionär
Alternativ Gaming Zeugs
Meine neueste UT MonsterHunt Map MH-MeltTown:
http://www.planetmonsterhunt.com/viewto ... =5&t=1343i
und Empfehlung des erstklassigen Shooter Games
Command & Conquer Renegade bei dem jedem
SciFi TableTopper vor Freude das Herzelein hüpfet ... .
:razz: :razz:
Kaal979
Milizionär
Milizionär
Unreal Tournament 2004
Schaut euch das UNREAL TOURNAMENT 2004
mal genauer an - da sind auch viele diabolische Charaktere drin.
Besonders wenn man die zahlreichen ExtraModels runterlädt. Die beste Seite scheint
http://www.utzone.de/ zu sein aber http://skincity.beyondunreal.com/ hat auch noch einige.
Das Spiel ist besonders zu empfehlen da es bessere PC Performance bietet und Fahrzeuge.
Auf http://www.moddb.com und anderen Seiten gibts auch neue Waffen und dergleichen mehr.
Die Charaktere sehen zwar irgendwie billig aus aber man kann mit gutem Ergebnis
den Grafik Kontrast verstärken. Wem das DoubleJumping nicht gefällt der wählt einfach
den ClassicUT Mutator oder andere.
P.S.: Zuerst dieses PatchPack downloaden: http://download.beyondunreal.com/filewo ... gapack.exe
Es ermöglicht den Start ohne DVD und enthält unter anderem den letzten Patch.
P.S.2: Das nenne ich mal eine MOD:
http://www.moddb.com/mods/ballistic-weapons
